Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 420A DSM Tech > 420A Bolt-on Tech
420A Bolt-on Tech Intake, exhaust, ignition, fuel system, cooling, etc - specific to 2G N/T DSMs. New Members must limit their 420A tech posts to this forum.
Reply
LinkBack Thread Tools
Old 04-17-2003, 04:40 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: Mitseclipse101 is an unknown
boring the throttle body...
i was wondering if any one has done this and if they had any problems with the throttle plate being stuck open, thanks
Offline
[posts] Reply With Quote
Related 420A Auctions
Sponsored Links
Old 04-18-2003, 01:04 AM   #2 (permalink)
Proven Member
Reputation: 4G63luvr is an unknown
Which part of the throttle body are you planning on boring, I did my Mikuni 62mm on myself. You need a new butterfly, you need to be good with a grinder and sander and a welder(sometimes) Are you talking about just thinning down the butterfly and bar that holds the butterfly ( don't know proper name?
PM me cause I can never find these darn threads again.
Chris.
Offline
Old 04-18-2003, 03:13 PM   #3 (permalink)
Proven Member
Classifieds Rating: (3)
Reputation: na90dsm is an unknown
60mm throttle body will flow more than enough air for a n/t. sink your money into something that will give you a good upgrade.
what are your mods so far. id at least have a full exhaust system, intake, k&n spark plug wires and other bolt on stuff before worring about the throttle body.
the only way youll need a bigger throttle body is a crazy head build up with like 2mm oversized valves in it, or a real high compression ratio
Offline
Old 04-18-2003, 03:16 PM   #4 (permalink)
Proven Member
i have exhaust, intake, ngk plugs and wires, and a NX 50 shot, i plan on getting a new intake maifold so the throttle body would help out alot
Offline
Old 04-18-2003, 03:19 PM   #5 (permalink)
Proven Member
it wont help that much. on a turbo app maybe but your not flowing that much air here.
go with cams and a little head work. that will help out more than those mods. on the 1g n/t 60mm throttle body and a stock intake mani wil lflow enough for about 225hp on a n/t. getting more than that, yea youll need em but i dont think you need them as much as cams.
the cams will give you a better jump in power and its cheaper than both those mods
Offline
Old 04-24-2003, 08:33 AM   #6 (permalink)
Proven Member
Reputation: turbo_awd is an unknown
I put turbo cams in my n/t and it gained 35 hp on the dyno its almost like a turbo 181@6300 not bad for a n/t
Offline
Old 04-25-2003, 06:47 AM   #7 (permalink)
Proven Member
Reputation: kamakazy59 is an unknown
you can pick up a 60mm at www.modernperformance.com .
Offline
Old 02-02-2008, 03:32 AM   #8 (permalink)
Proven Member
brassc2007's Avatar
Region: Midwest
Reputation: brassc2007 is an unknown
Hey got a question for you guys i have been searching for a while now on defects with the throttle body boring process and i have only found one flaw, and that is if you bore to much you will bore into a airstream dam and have to fill it and drill it back out. I have bored out a couple tb's but like to take all precautions as to not totally screw them up beyond repair. Do you guys have any other thoughts on the situation or suggestions that may be helpful on a good bore diameter without goin to far on a 1997 talon with the 420a thanks
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.14371109 seconds (71.54% PHP - 28.46% MySQL) with 9 queries
