Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 420A DSM Tech > 420A Bolt-on Tech
420A Bolt-on Tech Intake, exhaust, ignition, fuel system, cooling, etc - specific to 2G N/T DSMs. New Members must limit their 420A tech posts to this forum.
Reply
LinkBack Thread Tools
Old 07-13-2002, 03:29 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: SectorSe7en is an unknown
what do i need to swap a 1.8 widda 2.0NT
im about to do an engine swap from a 1.8 to the 4G63, what do i need to replace? what can i keep? ex...tranny....intake manifold...ecu
Offline
[posts] Reply With Quote
Related 420A Auctions
Sponsored Links
Old 07-14-2002, 09:59 AM   #2 (permalink)
Proven Member
Region: Eastern Canada
Reputation: HITNRUN is an unknown
You need a new intake manifold, exhaust manifold to fit a 4G63. You can keep your 1.8 transmission. As for the computer and wiring. I believe you need a new computer. As for the wiring harness i'm not completely sure. My Laser had a 1.8 in it and was replaced with a 4G63. There are plugs in the wiring harness that have nowhere to go. So I'm not sure on the wiring situation.
Offline
Old 07-17-2002, 06:26 PM   #3 (permalink)
Proven Member
Reputation: soundman707 is an unknown
This was written to me by fast1.8sohcDSM. I had the same question and this is what he said:
To answer your 4G63T question, that is simple. ITS HARD AS HELL, ! THe transmission, for one, yeah its the same size, the fork is the same size too, but lets put it this way, you have a 5 BOLT flywheel, and it's defintely smaller, and you also have a small clutch set. SO that would all have to to replaced. Now if I were you, and I am not, I would make sure I have some good experience under my belt before I start thinking of doing a conversion. YOUR WIRING HARNESS IS TOTALLY DIFFERENT, your missing your coil pack wires, and the Cam/crank shaft positioner. Not to mention knock sensors and all that crap. So basically you would have to put a new wiring harness in from a turbo 1st gen, buy a turbo'd ECM, if it didn't come with injectors, you would have to get them. ANything it didn't come with you would get. THe only compatable thing you would have is your air filter. LoL, I know that sounds rediculous, but its the truth. A conversion of this mulitude, would cost... I would say around 2.5K.
Offline
Old 07-18-2002, 04:55 AM   #4 (permalink)
Proven Member
2.5K?!?? plus professional installation?!? #@%#@%#@%#@% that...imma get that 1.8 of mine rebuilt
Offline
Old 07-23-2002, 02:48 PM   #5 (permalink)
Proven Member
Check this site out: http://members.aol.com/simonsez6/japengp.htm
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.11857796 seconds (71.05% PHP - 28.95% MySQL) with 9 queries
