Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 420A DSM Tech > 420A Bolt-on Tech
420A Bolt-on Tech Intake, exhaust, ignition, fuel system, cooling, etc - specific to 2G N/T DSMs. New Members must limit their 420A tech posts to this forum.
Reply
LinkBack Thread Tools
Old 06-23-2002, 09:14 AM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: GSterbo98 is an unknown
guys need your help!
i just installed a star stage 2 kit to my 98gs. i am looking to replace the 4 stock fuel injectors with new ones. how many cc's is recommended with a stage2, and what brand should i get? if any of you fellow dsmers can help me out i would appreciate it
Offline
[posts] Reply With Quote
Related 420A Auctions
Sponsored Links
Old 06-24-2002, 06:56 AM   #2 (permalink)
Proven Member
Region: Mid Atlantic
Reputation: gst_spyder is an unknown
Find out if stock 2g turbo 450's will work on the neon motor, you should be able to pick them up cheap off the trader and also start looking into a SAFC.
Mario
Offline
Old 06-25-2002, 10:42 AM   #3 (permalink)
fast1.8sohcDSM
Posts: n/a
If your pumping over 300 HP, I would look into 550 Injectors with a faster fuel pump to keep up. Also a S-AFC would help you manage your system lots better.
Old 06-25-2002, 03:03 PM   #4 (permalink)
Proven Member
THANKS ALOT GUYS!
Offline
Old 06-25-2002, 10:34 PM   #5 (permalink)
Proven Member
I don't think his stock bottom 420a with the stage 2 Star kit is pushing over 300hp, come on now... If they fit 450's are cheap and will get the job done. Aren't stock NT injectors like 190cc? 450cc seems plenty!
Mario
Offline
Old 06-28-2002, 09:09 AM   #6 (permalink)
Proven Member
will i run into any problems going from the stock 190cc to 450cc. like the engine flooding or anything?
Offline
Old 06-29-2002, 04:22 AM   #7 (permalink)
Proven Member
To put it in really basic terms- if a stock 210hp dsm can run them I don't see why not and like we said look into buying a SAFC to make it run better. I'm assuming your car makes atleast 200hp right?
Mario
Offline
Old 06-29-2002, 11:15 PM   #8 (permalink)
Proven Member
Reputation: Phoenix_RsX is an unknown
550 should work just fine i think. If I'm not mistaken, the hahn turbo I ordered are coming with 550cc injectors. After the dyno tune i should be no more than 285. You should be fine with 550.
Offline
Old 06-30-2002, 12:57 AM   #9 (permalink)
Proven Member
Reputation: 1TuffRS is an unknown
first of all the Turbo injectors will NOT work. Most turbo cars come with a certain type of injector (i forget what it is called) that isnt compatible with NT, or once NT, engines. You will either have to get some aftermarket injectors or find someone who wants to go halves on V8 mustang injectors. Also if you are gonna upgrade them you should at least get some 4- or 550's and a SAFC to control them. In all honesty the stock injectors should be OK when running 8psi, but of course the fuel pressure in your system will be a lot higher then if you were to upgrade your injectors.
Offline
Old 06-30-2002, 04:53 AM   #10 (permalink)
Proven Member
Yeah like I said before I wasn't sure if the turbo injectors would fit so in that case just buy the RC 550's man with the SAFC.
Mario
Offline
Old 06-30-2002, 10:32 AM   #11 (permalink)
Proven Member
Reputation: falcondsm is an unknown
You make a point about the Rods and pistons not holding up very well....BUt the Crank can hold Monster power....and also can we PLEASE not call it a neon engine...it is also found in the Avengers, Sebrings, and eclipses..and Chrysler has always been apart of the Diamond star family..infact when it comes to 1st gen Cars isn't the harnesses for the Cd Players a Chrysler component? Please it is a Diamond star motor...just from CHrysler...I am not trying to start and argument...just get a point across...and for the question...Accel makes kick ass injectors...or go to RC engineering and they will hook you up.
____________________________
7540
Offline
Old 06-30-2002, 10:33 AM   #12 (permalink)
Proven Member
1996 Gs Turbo 320 to the wheels
7540
Offline
Old 06-30-2002, 03:02 PM   #13 (permalink)
Proven Member
mario, thanks alot dude! i will do that.
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.15974808 seconds (78.54% PHP - 21.46% MySQL) with 9 queries
