wolfie359
- 72
- Jan 30, 2010
Roseville,
Minnesota
I currently have a Stage 2 Start Turbo System. 10:1 FMU, Walbro 255 Fuel Pump, ect. Currently I can run 14-16psi boost before getting knock on 92 octane.
Will my current O2 sensors work fine with E85?
I have stock 190cc injectors, but have a set of 1g 450cc stock injectors sitting on the shelf, do I need to use them for the higher fuel flow rate?
I have already replaced all rubber lines and connectors with Ethanol approved ones. Including in my fuel sending unit, and replaced the stock rubber gasket with a felt/silicone one.
I do have a narrow band A/F Gauge. Can you explain in detail the pros/cons between a Narrow Band and Wide Band A/F Gauge? Will this gauge even be accurate or usable while running E85?
I don't have the money yet for a programmable fuel management system, but at a later time/date I do plan on buying one. Just trying to figure out what I can do without one for the time being. I'm not looking to push a ton of power at the moment, just starting with run and run properly on E85.
Lets figure out how to make this work!
