1G Non Turbo 1.8L Engine Swap
illwill
66
Dec 16, 2002
Hey i have a 94 Talon 1.8L SOHC 5 speed. I was curious to how much it would cost to swap the engine with a 2.0L 16V DOHC. Everything i read says to just buy a new one with turbo. Well my insurance would put a foot in my ass, so thats not really an option. I have about $5,000 to lay down on it. Any idea on cost and parts needed? All input would be great. Thank.. and all work is being done for free
well i found one car i could get its only $1,000. Only thing is its a 91 eclipse turbo and it has 102,000 miles on it. Would the 91 engine fit into my car?
i think you can, 90-94 engine bays are the same except for the lights.. correct me if i'm wrong, and going turbo along with 2.0 swap is worth it... i would do it if i can find a turbo 102k mile car fo 1k :-/
if you dont do it.. tell me ^_^
Yea but lets just say i have alot of speeding tickets.. Mine would go up. O yea besides just the engine what else would i need out of the 2.0 for my car. I mean could i just do an engine swap without changing anything else? As you can see engines are not my strong point. I appriciate all the replys. Thanks
ECU
wiring harness
axles
motor mounts?
pretty sure the tranny is different, though I don't have much experience with the 1.8s
throttle cable?
clutch and shifter cables? Shifter linkage?
fuel pump?
MAS, aircan, intake pipe
intercooler, IC pipes, BOV
downpipe, cat, cat-back
Probably more, but it is 4am and I haven't slept in 2 days. Good luck :)
So would it be easier to just swap basically everything under the hood with the 2.0 then go about replacing parts with aftermarket stuff?
well i went ahead and got that 91 talon with the 2.0DOHC non turbo. I wont be doing anything to it till march when i drive to NJ cause my dads doin all the engine work for me. But with that.. what after market parts should i lean towards? Nothing to crazy im workin with a budget but if it helps i just wanna be pushin about 250 + hp..The more you post the more i learn LOL
o yea me and 91eclipseGS sound like were in the same boat here. Msg me man with any advice you have.And i still need to know if the engine bay of the 91 and 94 are the same so i can do this?
