djjohns55
- 78
- Jul 7, 2006
_,
South Carolina
Ok I'm currently troubleshooting a Completely stock 98 GS
I first changed the HG because water and oil were mixing. and I found out the head was warped. The car cranked up and ran quite well except for the leak.
I installed another head and the exhaust cam was binding because the engine was burning up the starter and it was insanely difficult to turn the engine over and it. It also broke off the dowel on the Exhaust cam. I trashed the exhaust cam and the head.
I got another head machined ground valves, cleaned and new valve stem seals pressure tested.
Now Ive worked out all of those problems and now I've installed the new head and timed it up and the engine turns over. It acts like it wants to crank but it will start up.
I'm getting fuel and good compression. Spark is iffy thing because I get good spark most of the time but sometimes I get a very faint spark on all cylinders. Ive changed the coil with a working coil and the engine acts like it wants to crank even more but it still doesnt. Ive changed the spark plugs and the wires are fairly new and they work well on my car.
The weird thing is that when I unplug the cam sensor I can get the car to crank and it runs quite rough it will not idle either. If I open the throttle body up, the car will run smoother but not perfect. While we had the car running I tried to plug the cam sensor up and it died.
I changed out the cam sensor and it still does the same thing. I havent changed the crank sensor yet but I was assuming that since the car will run w/o the cam sensor the crank sensor is good. My next step is to check the timing again,and check the crank sensor and if all fails find another ecu.
I've even swapped out the magnet on the back of the current exhaust cam that im using because one of the plastic dowels were broken.
NO engine codes! I scanned for some hoping it would help but nothing came up.
Could I have possibly messed up the ECU when the Cam was binding??
Can someone explain how the cam sensor and crank sensor communicate with the ECU?
What could it be??
Thanks for any input!!
What could it be??
