I am a noob with a holset hx40
THEMAN4LYFE
Dec 23, 2007
howell, New Jersey
Ive been tryin to find info on getting a v-band flange for the compresor out-let to no success. I would like to know if there is a site that might sell what I need. Link to my build page.
My 2.4 build - ASEClub
Any reason you're opposed to grinding the flange down enough to enable a silicone coupler to slide over it then clamp it tightly with a stainless t-bar clamp?
The reason I ask is because the charge piping on the diesel application that the HX40 was originally intended to be used on is full metal piping, hence the v-band clamp on the compressor outlet. Unless you locate the original piping somewhere then hack it apart just to use the v-band, your search may be endless.
Hello im using 2.5 piping myself. As for your v band needs your in luck i own a cummins. Go to ebay and type in dodge cummins turbo and or diesel in ebay motors. This will bring up all turbo related parts for it and you should find what you need. I think those pipes are like 3' so you would have to get a reducer to go with the size pipe you want unless using the same
