matt98eclipse
- 1,078
- Aug 15, 2006
mesa,
Arizona
Hey guys im in the process of builting a 420a and my adjustable cam gears cam in today. So tonight i installed them. Does the timeing look off?? I want to make sure the timing is dead on with this motor! This is my first Full rebuild. Here are the mods list. I cant wait to get this motor done.
bottem end
JE pistons
JE total seals rings
Eagle rods
ARP rod bolts
ARP Head studs
Clevitte 77 main bearings
Clevitte 77 rod bearings
Meilling oil pump
New water pump
Top end
Cometic mls head gasket
Ported and polished
1mm over sized valves ( feario or somthing like that)
Titanium valve springs
I have more build pics but heres a couple
bottem end
JE pistons
Eagle rods
ARP rod bolts
ARP Head studs
Meilling oil pump
New water pump
Top end
Ported and polished
but I believe that is correct as with the intake down and exhaust up it was wrong.
That is fine that won't change anything your cool.
