seized engine
chase172
Nov 4, 2007
Sandy, Utah
on a brand new motor w/ only 4k miles. starter tries but does nothing. a rolling start in 1st 2nd or 3rd does nothing but make the car shake like a mofo. oil was to the full mark and had no weird noises or anything. everything was acting normal. what in the world could this be? i'm pretty pissed off right now...
if you have an oil press gauge ? did it have any oil press when it was running?
Did it just suddenly one day not start-up or did it have probably before and then died? It the only problem is that it just doesn't start-up check your pressure, spark plugs, coil pack, etc... Do it crank? If you've had problem all along which led to not starting give more description.
