hippy
- 322
- Jan 18, 2004
chtown,
I just bought a 95 eagle talon 420 motor ( i owned about 10 dsm turbos) so this is new to me , anywyas i bought it with teh timing belt needing to be replaced so i did all the timing up tonight put stuff back on that was off but i tried to start it and no go. things i checked for no fire to plugs, no fire to coil no fire to cam sensor, no fire to injectors, did hear fuel pump turn on once check engine light comes on then goes back off. Would you guys say its the ecu or what else would it be i also checked all fuses and there all good too. Thanks if u can help!
