swap or not
psssshhhh
May 15, 2002
i have a question for all of you.
i can get a j-spec for my non turbo talon. would that be a pain in the ass to swap? wouold i need extra parts?
or should i put a turbo in it? will my car be as fast as other talon/clipes stock turbo?
thanks peace.
I would be a little weary about purchasing a "j-spec" engine. Several "performance" shops have tried to sell a j-spec 420a to some eclipse owners. Unfortunately there is no such thing. I would just be sure to look into it. I do not know what engine you have in yours since it is a first gen. But just research it before you do it.
whoa dude your sig is waaayyy too big. 120k 700x364... most of it is text so if you could pls just use smaller images and use text to point out what you've done.... im sure the forum administrators would appreciate it :)
  • For sale 2g 97-99 Mpi relay
    2g. 97-99 Mpi relay. Many don’t realize the later 2g doesn’t use the same mpi as the 90-96...
  • For sale 2g 2g window moulding
    2g pass side window moulding. Rubber is in decent shape. Has one dent. Front plastic end cap...
  • For sale Mishimoto Intercooler
    Universal Mishimoto Intercooler $100.00 Brand new
    • jmt2028
  • For sale 2g Mahle Power Pak Pistons
    2g Mahle Power Pak Pistons, factory bore $350.00 Brand new with wrist pins and extra set of...
    • jmt2028
  • For sale 2g Water Neck/Thermostat Housing
    2g OEM waterneck and thermostat housing $60.00 In good condition, came off 1995 Eagle Talon Tsi
    • jmt2028
