D'seclipse
Whats the compression for the 420a? 200 across all 4 cylinders? Thanks for the help.
Originally posted by abstraction
abover
, that is an awesome word.
Above or over. Compromise and make abover![]()
If you disconnect the coil, then how is the engine suppose to start?Originally posted by D'seclipse
You can go to an auto parts and purchase a compression guage for like 15-30 bucks depends on what you want. Then you have to pull a plug and disconnect the coil....i think...might check with someone else.
Originally posted by madracer247@aol
how and where di you check your compression on your car I was wondering I have asked and they want to charge me like 90.00 ok guys thanks
