error code 25
jeffreyinigo
65
Oct 6, 2004
Tucson, Arizona
hey guys i have a 95 rs with a manual tranny and got a code 25. how do i fix this... i have no idea what to do with it.. i know what it is, just dont know how to fix it....
any help is greatly appreciated..thanks ;)
allright cash money 25 could be a couple of things ive give you what they are and where to look to fix um ;)
1)Idle air control motor circuit
look at your, Harness and connector / Idle air control motor
Target idle not reached (k200 r/min)
look at or for, Harness and connector / Idle air control motor / Vaccuum leak
when i replaced my tb it gave me a cell 25 because my tb plate was open just a little bit when i was at idle
if you have done this or ajusted your stock tb plate try moving it back to the original positon as well and it should fix any problmes
hope i helped
aliczander :talon:
Check for vacuum leaks. Most of the time the computer will look at Throttle position, engine RPM (target and actual), and Idle air control motor stepper count (target and command). If TPS shows closed, Engine RPM is not within 200 rpm of target, and the IAC motor is being commanded all the way closed then this code will set.
How does the car idle? Do you have any symptoms OTHER than the CEL? We need more information in order to help you with this problem.
Doug
