97eagletalonesi
- 371
- 1
- Jun 5, 2004
moberly,
Missouri
ok i found some turbos on ebay the first one is a super t70 specs on it says
Kit comes with 3 parts
1. Equal Length Manifold
2. 38mm Wastegate
3. T3/T4 Stage III 57 trim turbo
4G63 turbo eclipse Manifold
first and second generation eclipse
304 high strength Stainless steel, tig welded
Made to mount to T3, T3/T4 turbos
Tial wastegate flange
Comes with gaskets and mounting hardware
38mm wastegate
Comes in different spring rates
Upon winning specify size
Comes with Flanges, Gaskets and Mounting Hardware
Brand New not Rebuilt
Super T70 turbo
" WET FLOATING BEARINGS"
SHAFT & WHEEL TRIM 64.5mm
COMPRESSOR WHEEL SUPER 70 60.5mm
TURBINE HOUSING A/R .84
COMPRESSOR HOUSING A/R RATIO .70
they want 800 for it what kind of boost can i run with this one
then the other one spec is a t3 i belive
2. 38mm Wastegate
3. T3 turbo
OBX 4G63/4G64 turbo eclipse Manifold
With Lifetime Warranty
first, second and third generation eclipse
Including Spyder models
38mm wastegate
T3 turbo
0.42 compressor A/R
0.48 turbine A/R
THIS TURBO CAN EASILY DO 20+ psi
Standard T3 ~ T3/T4 Flange, 4 Hole Exhaust Flange
im a newbie for turbos not sure what some of the specs really mean but im assuming the first one is better i can buy it now for 800 on the first one with free shipping is that a good price. and also on the 38 mm wastegate what spring rate are they talking about.
i posted it in a nt turbo conversion but have had a reply yet
2. 38mm Wastegate
38mm wastegate
Super T70 turbo
2. 38mm Wastegate
3. T3 turbo
38mm wastegate
T3 turbo
0.42 compressor A/R
0.48 turbine A/R
