what are the specs on a stock GST?
what are the specs ona factory 2g gst?
0-30:
0-60:
quarter: 15.0-15.2
topspeed:130-140
whp: my calculations say 178.5 but that seems low.
torque:
0-30: who cares but i would say around 4s or 3.7
0-60: 6.5s
1/4: 15.0
top speed: 130 mph
whp: 180 - 182
torque: i use to know this... but its either 205 or 220. hope dat helps
:dsm: :dsm: :dsm:
NyteDSM96 said:
yeah sumthing like dat, however it varies from spyders i believe.
:dsm: :dsm: :dsm:
it only varies with the Spyder GS which uses the 4G64 not the K20A. It reaches its peak horsepower sooner and more torque than the K20A. The spyder GS has 141 HP @ 5500rpm to the K20A 140 HP @ 6000rpm. The torque is much more usable to move the heavier body the 4G64 reaches 148 lbs/ft @ 3000rpm to the K20A 130 lbs/ft @ 4800rpm.
The spyder GST has the same 4G63 engine, which is rated at 210HP @6000rpm and 214 lb/ft @ 3000rpm as the GST coupe and GSX.
what the hell is a k20a? an assault rifle?
