AFPR on 2GNT???
I had my head rebuilt with larger valves and my car is running lean now.I changed the fuel filter out and still have the same problem.Eventually I am getting a turbo kit and will need it anyways.So who sells them???
Fuel pressure regulators are universal. You are lucky in having a return fuel system that makes it much easier to deal with. If you look around in any performance shop you should find one. The current favorite and champ seems to be the Vortec S-FMU which gives you a lot of adjustability and is proven to be solid.
Also curious how lean you are runnig and what makes you think it is lean.
On a side note, if you buy a turbo kit, they will include a fpr as standard.
I won't know exactly how lean I am running until tomorrow.When I took my car in to get it dyno tested,we were looking at the different runs and every time the temperature in the bay increased 0.2 degrees my car woukd gain three hp(on the average).Also the graph on the dyno looked like I had a honda engine(V-tech).I wish I could post the graph,but I don't have a digital camera or scanner.It ran strong from 3k rpm in 4th gear to 4200 and then it dipped really bad until 5k,then it shot back up again until redline.The owner of the shop is the one that told me I am running lean and I trust his opinion.
As for the turbo kit.I am having a custom kit built in South Africa right now and I told him I would get the AFPR myself.I would tell you how much,but I don't want to post it in the forums yet.
