420A what would i need to.....
macegs
Aug 1, 2002
North richland hills,
i have desided to just drop a turbo engine in my car.I have the engine,but before i do anything stupid,i wanna know from the smartys what will i need to do this.Like a ecu and what else.thanx.:D
Turbo ECU
Turbo intake
Stronger Clutch
2.5"-3" exhaust
O2 Housing
Downpipe
Side Mount Intercooler, BOV, And all Piping
Knock sensor
MAS from a turbo 1g or a converted 2g MAS
Boost Gauge
EFT Gauge
Air to Fuel Ratio Gauge
New Vacuum Lines corrected
Some sort of a boost controller
That's just the big stuff... I think there are smaller things.
Depending on how much boost you want...
For larger boost - bigger fuel pump, thicker gaskets, turbo timer, SA-fuel controller...
To add on to what he said:
here's the list.
ENGINE:
1. complete turbo long block (blcok and head including internals and bolted attachments such as oil pump and such).
2. mass air sensor
3. fuel pressure solenoid
4. turbo intake manifold and throttle body
5. turbo exhaust manifold
6. turbo and related cooling and oil lines
7. intercooler (side mount or front mount)
8. intercooler piping
9. turbo fuel pump
10. BOV
11. turbo injectors
12. injector resistor pack
13. 1g fwd downpipe
transmission
1. nt clutch new or old/ upgraded or stock (my stocker held with 30,000 on stock nt clutch replacement)
2. you'll need to grind off the location pin for the turbo flywheel so you can use the nt flywheel.
(note) the turbo flywheel and clutch will not fit inside the nt bellhousing w/o scratching it up and locking up the engine.
This was taken from another forum.
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
