fast1.8sohcDSM
I wrote this, only because I feel people need to ask themselves if they are ready for this upgrade.
Many people think if I go turbo, my problems are over. Ha, the beginning is when you go turbo. The problem is guy's, if your a NT, and you go turbo, you run into problems. You have to decide if you have enough money to supply the continues modifications you will buy. You will have to understand, running low octain gas will be it, and from now on, when you look on the gasoline, you're getting the most expensive one. You also need to realise, am I a good enough driver to handle this kind of horsepower? I know you're laughing, thinking,
, this kid must be ***. Hell no dood, I have seen people who can't control there car because it out-does them.
Now ask your engine a question, can it handle the preasure of a turbo. That's hard to not think about. People who don't think before doing usually end up with severe problems/results. You have to make sure that this engine has good mileage on it, and that your engine life won't be completely destroyed by 120K on your engine.
A good way to lower compression for your car, is to run a 2mm head gasket. If you run your engine this way without turbo, expect 10% hp loss. Big loss if you ask me. But if you run it turbo, you can see your compression drop incrediably, and see that you can run high ammounts of psi going as far as your pistons and rods can take you.
You will have to look into manifolds, and the turbo you are planning to buy. You will have to change exhaust manifolds. No doubt on that. ANd you will have to change your downpipe, that is a must. Your fuel injector's and fuel pump will have to be changed if you start feeling fuel cut. To get better management, you can buy a Super-AFC, or you can look into other management systems such as the AEM EMS, that totally replaces your ECM = Engine Control Module, and then will be totally plug/play.
Some things for a turbo, you will need to figure where you want to get your oil. On the 2.0's, I believe there is a place on the head. As for the 1.8's, ahead of the oil filter, where we get clean oil is where you would hook that up. As for a return you can buy a 4G63 oil pan if you have the 2.0, and the oil vent, and then use that. For the 1.8, as long as you can find a way to get it back to the beginning, you'll be fine.
Other small thing's you'll need are a Boost Gauge, a 2/3 Pillar, so you can house these gauges. A Exhaust Gauge can't hurt, and a Fuel/Air Mixture gauge. Those are some nice things to have.
Also remember, change your timing belt before you do this, and make sure that you have 8+mm spark plug wires. NGK spark plug's work nicely in our DSM's.
, this kid must be ***. Hell no dood, I have seen people who can't control there car because it out-does them.Now ask your engine a question, can it handle the preasure of a turbo. That's hard to not think about. People who don't think before doing usually end up with severe problems/results. You have to make sure that this engine has good mileage on it, and that your engine life won't be completely destroyed by 120K on your engine.
