Installing safc-2 questions.
rated x
140
2
Jul 13, 2005
yorktown, Virginia
I have a maf-t in blow-thru setup and just got my safc-2.My question is when I hook up the safc-2 do I have to zero out all the knobs in the translator(aux,base,idle,mid and wot)?
Also when the safc-2 is turned on for the first time,if I have a gm maf sensor do I still have to put it in as karman for the sensor type?Is it 2 or 4 for the # of cylinders?Does it matter that it's a 1g in a 2g?
Well instead of making a whole bunch of questions.How do you do the initial setup?
thanks guys.
Does it matter if I have a 1g in a 2g?What about if I have a maf sensor with the maf-t?Does the settings have to be different?
Don't set everything to zero... You at least want to have it set for 450cc injectors.
When I had a MAF-T/AFC combo, I found I got the best results when I used the MAF-T to get my fuel trims dialed in, and then I used the Hi settings on the AFC to tweak the tune at WOT.
