N/T Sypder owners (Fog Lamps on with Park lamps)
This is for the non-turbo sypder owners out there. Okay this is really simple to do. First off you will need a fuse BLADE holder with enough wire to run from the fog lamp fuse to the taillight relay. Second get you will an extra fuse which needs be cut it in half (does not matter if it is blowen or not) it's just used to hold the wire in place. Okay once you have remove the fog lamp fuse (do not throw it away because you are going to need that fuse) and the taillight relay take one of the wires from the fuse holder and place it in pin#4 which in the middle second one from the bottom facing the fender (first left to right it goes from pin#1 to pin#3 across the top and pin#4 is in the center facing towards to the passenger side fender). Once you have placed the wire in pin #4 take the other wire and place it in the slot closer too the fender where the fog lamp fuse was then take one half of the fuse you cut and place it in the slot where the wire is to hold in there. Finally turn on your park lamps and your fogs should come on if not you have the wire on the wrong side that is running to the fog lamp fuse circuit no bigger just switch sides but just make sure it is in the slot on the left closer to the fender and you will be okay. No this will not bypass the switch off during the high beam use. I will pose pictures in a few days to help you out. Caution!!! This was done on my 1999 sypder, I sure it will work on a 1998 but not sure about 1997 or 1996. If you would like to try it and it works please let me know. WARNING!!!! If you have your brights on even if the headlights are NOT on the fog lamps will not be on so make sure your brights are off before bypassing the circuit
