Fastener Torque Values [Merged 3-9] value tightness torques specs specifications
GreddySpyder
414
Oct 21, 2002
Alabama
I changed my leaky oil pan gasket not long ago and it is still leaking. I used red rtv as the gasket and ran a nice continuous bead around the whole pan making a circle around each bolt hole. I think the two mistakes I made were not waiting for the RTV to dry before putting the pan back on, and I think I tightened the bolts too much ( I ended up breaking one of them).
I'm gonna buy a torque wrench and make sure they are right this time... how much torque do the pan bolts require? How long should I let the RTV dry this time before putting the pan back on?
pnklmnd said:
Im doing a head gasket, and was wondering what to torque the bolts to.
on a cold engine you would tourqe 65 to 72 in the right sequence. #1 being the middle stud on the exhaust side, #2 being the middle intake,#3 to the left on the exhaust side,#4 caddy corner from #3, #5 to the left of the middle intake, #6 caddy corner from that, #7 last on the left intake, #8 last on the right exhaust, #9 last on the left side exhaust, and #10 last on the intake right side.
Mike
(right and left as you look from the front)
How do you get as far as doing a head gasket with ZERO refrence material? (Haynes/Chiltons/DSM Manuals/CDs)
Here is something I just dug up real quick, hope it helps....some.
gsxtacy
Thanks.
To be honest i have never looked at a haynes, chiltons, DSM cd or the like. Ive done 5+ motor swaps, bunch of clutches. The only reason i ask is id like to know the exact torque they need to be.
Please note that if you are using ARP headstuds that you will need to torque to 80 ft/lb and using the ARP moly lube
also, if you are using a 1g headbolt, that the torque sequence (not the order in which you torque, but how you torque) is DIFFERENT because the 6 bolt studs are not a stretch-type like the 7 bolt is. use the above sequence ONLY for a 7 bolt..
Exactly. The 1g only needs to be tourqed once.
Mike
But the the pic of the tourqe sequence in the is correct.
I got your PM, but I guess i'll post up here for the rest to see. if you are using STOCK 6 bolt headbolts, torque once, in the appropriate sequence to 75 lb/ft. oh, and don't reuse your headbolts if you're planning to. even though they are not stretch-type, it could be possible that they will not fasten as well once you remove them
ARP's are good to torque in the above sequence, but in 3 steps. 30, 60 , 80.. or whatever interval you'd like.
I was just working on mine this eve. It is unnerving to torque them to 14 lbs! I have a snap on digital wrench and 14 lbs just seems loose. Needless to say they are just a tad higher.:coy: Dave.
so im finally getting around to putting my engine together and when i dropped the arp rod bolts off at the machine shop they kept the instructions. now is there a different torque reading for the rod bolts with the arp hardware? also what should i torque the head bolts to with the aro harware. thanks a lot guys.
on the rod bolts, the torque value isnt bad to go by, but you really need to ensure the proper bolt stretch. This is much more important. Ive noticed on motors ive assembled where torque values for eagles etc is 50ft lbs, it requires much closer to 55 ft lbs for a proper rod bolt stretch. This with a recently serviced torque wrench.
I feel that when using new rods, then the torque value is fine to go buy. If it were stock rods utilizing ARP rod bolts/studs, then the stretch method is what you need to folow.
BrokenTsi said:
not every torque wrench is the same, or serviced recently. And many torque wrenches are correct within +/- 4%. Ask any quality engine builder they will go on and on about how important rod bolt stretch is :D
ROFL
how do you measure the botl stretch
Do you use a hi-temp thread lock or anything? i bought a 6 bolt and have started taking it apart, and plan on putting ARP through out the whole thing.
