Generation X
- 504
- 6
- Aug 12, 2003
Asheville,
North Carolina
I've not been to a 1/4 mile track, but I trapped around 87mph in the 1/8 on my FP B28 (FWD). It was also very hot and muggy the night I ran. The temp was about 75 to 80 degrees, and I was also about 1800ft above sea-level running about 21psi, with it dropping to around 19 psi by redline. I haven't run yet with my Zex wet 75 shot kit that I just installed. I'd probably say around 115 to 118 traps in the 1/4 on spray should be obtainable.
. So... now when I try to lower the boost with my MBC I can't get it to lower the boost at all. I'm not sure why this is happening.
