from the vin id on the door it says january 90,the vin is4a3cs44r4le******,and i have noticed other problems like this in the past with the ecu pins,when i was adding my a/f ratio gauge i was trying to go from the ecu but where everyone on the site and vfaq says the wire should be there was no wire in the location.do you have any clue what i should do?is there a site that will show the asctual break down for each 1g?maybe i can look at each and piece it togeather.
