DSMLink Here> Installed Cams, Rich Tune, Pump Gas, Lots of Knock!
project_tsi
Honorary DSM Wiseman
DSM Wiseman
2,699
118
Sep 4, 2004
Eau Claire, Michigan
Alright Im in need of help. 91 FWD. I recently Installed a set of Comp 101200 cams, similar to 272's, and now I have a ton of knock that I can not get rid of. As soon as I hit approx 18 psi the CEL goes off and never quits. My boost is set a 20 psi, but w/ internal gate it creeps to 25 but not like I can keep it floored long enough for it to creep. I am running 93 oct., no means of water/meth injection. A Turbonetics/Bullseye 50 trim at 20 psi, FIC 650's, 255 HP pump, Aeromotive FPR, SBR IC, Blowthrough Maf, yada yada, oh and Innovate Wideband 02. Now as soon as I hit approx. 18psi, I knock but my A/F ratio is approx 10.3 or lower. I have no timing advance, as reset my settings when I installed the cams, and then tried tuning from there w/ no luck. All I want is for the car to pull like it should w/ cams at 20 psi w/out knocking. I am new to this whole DSMLink and even tuning scene so please bear w/ me here. I cannot provide logs right now as my laptop is not w/ me, but if anyone needs more info I can try to provide whatever info you need. Something I tried is advancing my base ignition timing b/c previously before the cams installed I found the car ran better a few degrees advanced but actually now knock is comming on faster than w/ the timing at stock. Should I try retarding base ignition timing a bit? Could I just be running too much boost for the octane level I have? I doubt it b/c someone I know recently installed FP2's and his car is running great on pump gas, so I dunno.
Please help me out, I'll try anything, cus right now $400 worth of new cams is slower than w/out them.
Thanks guys, Dan.
I have also posted this over on the DSMLink Forums so don't tell me to do that!
try running like 2* base timing. if youve got the dsmlink you can advance it where you see fit.
  • For sale 2g 2G DSM ECU
    Came off a 1997 GST M/T. Stock ECU
    • Stizzydrew
  • For sale 1g 90-91 Talon pass taillight.
    Pass taillight for 90-91 Talon. Good condition. No breaks or cracks. Will buff up nice...
  • For sale 2g 2G Manual Window Assemblies, Door Panels, & Hardware
    2G Manual Window Assemblies, Door Panels, & Hardware $250 + shipping and paypal feesYou must...
  • For sale 2g 2GB Talon Wing ( 3rd brake light included )
    2GB Talon Wing $90* pick up only in 08096 NJ * 3rd brake light includedYou must be...
  • For sale 2g 2GB Talon Front Bumper
    2GB Talon Front Bumper $200* pick up only in 08096 NJ * tear on the bottom side, picturedYou...
