Air/Fuel Ratio Gauge Install in a Syder GS N/T
1. Disconnect the negative cable the battery.
2. On the driverside remove the console bottom cover. It has (1) one screw beside the acceleration and right in the middle it has a cover that has to be popped off to get to the snapp press gentle pull the panel forward to exposse a (4) four wire pig tail with the colors of white(singal wire) black(ground) red(power)which comes on when the key is turned to the on to start postion and yellow/green wire(neutral). NOTE: you may have to pull the carpet back a little to see the (4) wire harness, but it is right beside the driver seat.
3. Take your air/fuel ratio gauge connect the purple wire to the white wire, the black wire to the black wire and the red wire to the red wire. Reconnect your negative battery cable start car and let sensor heat up, at first you will see nothing after it the car runs for a minute or less you will see it start to read as the exhaust heats up.
4.Enjoy!! Tune!! and Display!!!
Sorry, I do not have any pictures. I will try and post some soon.
