My 1st Log on 1gen
shortydtp
488
11
May 1, 2005
Phoenix, Arizona
Heres is my first log , I bough the car 2 weeks ago , and mods so far is: hacked maf, MBC, at 15psi K&N. and test pipe , no cats. and wired 255 walbro
so heres is my logs fuel trims are 81.2 on L M H
2nd gear pull
RPM Knck TPS O2V INJP TIMING
4031 1 100 .93 15.10 26
4281 0 100 .95 20.73 17
4531 0 100 .95 23.55 18
4750 0 100 .95 22.27 18
4906 0 100 .95 22.27 19
5187 0 100 .95 20.99 19
5375 0 100 .93 19.96 20
5562 0 100 .93 19.71 22
5718 0 100 .93 19.71 23
5875 0 100 .93 19.43 23
6093 0 100 .93 17.91 24
6218 0 100 .93 17.40 24
switch to 3rd Gear
4312 1 100 .93 16.89 27
4437 0 100 .95 22.27 17
4468 0 100 .95 21.75 18
4593 0 100 .95 22.52 18
4687 0 100 .95 22.27 18
4750 0 100 .95 22.78 18
4843 0 100 .95 22.01 19
4873 0 100 .95 22.01 19
4937 0 100 .95 22.01 19
5062 0 100 .95 21.24 19
5187 0 100 .95 21.24 20
5250 0 100 .95 21.24 21
5343 0 100 .95 20.73 20
5375 0 100 .95 20.73 21
5406 0 100 .95 20.47 21
5531 0 100 .95 20.49 22
5593 1 100 .95 20.22 22
5593 1 100 .95 18.94 22
5687 0 100 .93 19.19 23
5750 1 100 .93 18.94 23
5781 1 100 .93 19.19 22
5843 0 100 .93 19.19 23
5843 0 100 .93 18.68 24
6000 0 100 .93 18.17 24
6031 0 100 .93 17.91 24
6062 0 100 .93 18.43 23
6062 0 64.8 .93 2.30 24
What do you guys think?? 1st gear it pulls pretty stong same as 2nd , but 3rd it feels like kinda slow, and sometimes it jerks a lil.
Thank you!
well i don't have nothing to tune or lean it out yet , but i can always boost up a lil. ;)
but is there any other thing you guys see that might be wrong??
how about timing? or why3rd gear doen't pull as much.
Thanks again.
Jose
boost it til you get at least get some knock then turn it down a few psi and lean it out.. but without a SAFC you stuck with factory AF so if you can get it up to 18psi i would suggest advancing your base timing until you get around 5 counts....
