TalonTSIYHL
- 77
- 1
- Aug 4, 2002
Madison,
Wisconsin
ok here goes: i have a 92 talon tsi awd 6 bolt auto with 125K on it. It feels like there is no power without boosting, its like i have to go the 0 on the boost meter just to get it to 35mph in a decent amount of time. and even boost doesnt seem as powerfull as it used to. There is alittle oil in the valve cover and once in awhile at WOT there is a cloud of greyish to white smoke out the back, i also have decreased gas milage. i did a compression test the other day and got 150 150 150 and 130 (the 130 being closest to the driver side). The spark plugs were burnt white and black. After the wet test the 130 went up to 180 or so, im guessing its the piston rings then. i havent done a leak down test due to the lack of equipment. if i got to do then rings then i might as well do the head gasket and rod bearings and hone the cylinder walls. Is there anything elso i should do. I would like to spend the least amount of money but still make sure its running strong. I plan on doing the work my self even though i havent done anything at this level but i have all summer to get it done. i am also unsure what parts to buy, what is all included in a "engine gasket kit"? goes for about $200. Any imput on which part to get or where to get them would be very appreciated. sorry for the long post, thanks in advance.
