SjJones
- Jan 14, 2012
Baltimore,
Maryland
im hoping i didnt screw up with purchasing this car. ive fixed alot of the previous owners screw ups and problems, but now im running into more. today my car wouldnt go into any gear, it would either grind real bad or just flat out wouldnt go in, when the car was shut off i goes in all the gears fine. usually while driving it grinds going into 2nd gear. is that just my clutch going out on me? the clutch pedal still feels fine and i previously replaced the transmission with another factory one. looks like theres a small leak under my clutch cylinder as well. I also noticed a leak behind all my timing belts on the block. I'm supposed to take it to the shop tomorrow to get 2 bolts for my turbo manifold rethreaded on my block (the 2 bolts just pulled right out when i replaced the manifold), that too looks like its leaking in that area, but i think those missing bolts would be causing it? any ideas on any of this?
