1998 eclipse gsx build
Arcangel2501
47
Jul 26, 2012
Okc, Oklahoma
Hello all im about to start ripping apart my 1998 GSX and bulid it i have order alot of parts off the bat the last 4 days this is my bulid if you see parts that i list that have had better results let me now
Engine bottom end
CP. pistons 10.1
manley turbo tuff rods
stock crank
new oil pump water pump
gates timing belt and assiories
Engine Head
Port and polished
ferrea valves set 1mm oversize RPM 11 k
3G lifters
hks cams 272/272
hks cam gears
ect.
Fuel Set Up
F.I.C 1800cc injectors
duel 255 hanging fuel pumps
aem fuel rail
aem fuel perssu. reg.
Fuel E-85
ect.
Turbo Set Up
Precision PT7068 ball bearing
STM mainfold T3 Duel Waste Gates
Magnus intake mainfold
G35 Throttle Body 90mm
Precison F.M.I.C rate at 950hp
2 Tial 44 mm Wate Gates
Ect.
Drive Train
Shep Stage 4 Tranny
Clutch master lighten flywheel
Clutch master twin disc Clutch
D.S.S single drive shaft Rate 650+
D.S.S Haft shafts 650+
D.S.S Axles 650+
Brembo brake upgrate front and rear
Suspension
KW Coilovers
KW Struts
KW Camber Kit
koni Lower and upper control arms
Engine Man.
DSM Link V3
Aem Boost Bye Gear
wheels and tires
18's with nt0 555rs
tires size unknow at this time
let me know what you guys thing will be taking pic of everthing coming in and youtube some video of engine being put together ect.
