installing tbelt and bent valves
BLOHS7844
300
Oct 25, 2011
Appleton, Wisconsin
When installing a timing belt, I had the cam marks pretty much lined up (both could have been turned in just a hair) and I was rotating the crankshaft so to line up that mark. It got kinda hard to rotate it (no spark plugs so no compression) and it made a weird noise, somewhat like a scraping noise. Is it possible that I bent some valves?
yes and no. It did get harder but it was something that didn't take much force. Maybe 20ft/lbs? That is a very rough estimate btw. It was noticeably harder than it was before that
When I turned one of the camshafts a quarter turn I was able to continuously rotate the crankshaft easily
Yeah I've done the same thing and never bent valves before so as long as you weren't cranking on it real hard I'd say you're probably fine.
When my cam timing marks looked a hair off it was when my dowel pins for the cam were facing down, they looked perfectly strait with them up. Make sure you didn't time it 180* out, but I don't know if that would effect the valve clearances.
You can also do a garage leak-down test with a compression tester fitting and regulated air to check for bent valves.
