98 GSX exhaust
wicked98gsx
139
Feb 17, 2012
Middlesex, North Carolina
Ok so from what I have read on the exhaust specs of my car... Stock exhaust piping is 2.5", correct?
To pass inspection, i needed a new flex pipe and a new cat(both rusted out)... I tell my local muffler shop that I want it replaced and money wasn't a problem, just fix it.....
Well he did... with a standard weld-on cat and a 2" flex pipe! How bad is this hurting my engine and turbo? They are no where close to the size of the OEM exhaust pipes
Well i just measured my stock 99 gsx O2 housing and its barely over 2". So whoever said it came stock with 2.5" is very wrong. My aftermarket apexi downpipe starts at 2.5" and goes to 3" after the flex pipe. If the stock exhaust system opens up after the downpipe (which I'm not sure it does) i doubt it goes bigger than 2.25". Is your car completely stock? If it is, then its not hurting anything at all because this is the stock setup for our cars. Could it benefit with bigger piping, of course but your still limited if everything else is stock.
Ok good. I googled GSX exhaust specs and kept getting the 2.5 answer in most places so I assumed (yes I know what that gets me).....Im going to have a custome exhaust made later but I just done want this small flex and cat causing any running issues. So thank you for the responce man. You guys up here help out alot for noobs like me
