4g63 AWD Mirage runs 9.61 @ 143!
XLR8
250
20
Jul 7, 2003
Kingston, New Hampshire
Great run! Any info on the setup? Turbo,fuel etc...
Believe he is on here somewhere, may be able to chime in. I know high z 1250's by fuel injector clinic and turbo is FP hta 3586 if I remember correctly.
I love it!!!!!! What's the "light" or fire that you can see in the passenger side of the bumper on the launch?? I like the main exhaust exit too, very stylish and much cooler than the standard bumper side exit IMO :D
how much boost, timing etc...?? what fuel also (if you don't mind sharing this info??)
Not sure on the boost level, timing, I believe c-16 on the fuel. Think the light is just the starting beam.
Who is the turbo manifold by? The car seems to have alot more in it, as I can see it's still running a stock intake.
FP manifold. The car is getting a SMIM and upgraded TB installed before the next track outing. Also after some discrepancies with the turbo and calls to fp it was determined that the turbo is actually a 3082 not a 3586.
WOW! Am I the only one that's EXTREMELY impressed to see 143mph from a gt30 turbine in a bolt on dsm housing??? That's pretty damn incredible!
My car has done 114 IN THE 1/8 aswell. What is amasing is this car runs 9s and i'm still stuck at 10.14. My car did trap 146 so I think the owner has alot left in it aswell. Great job getting it done. How much does this car weigh and what kind of power does she make?
Amazing run. Even more impressive then the time is how straight down the track you kept it. Looked like it was on a rail!
That's awesome and all, but what does that have to do with a gt30 turbine in a bolt on dsm housing??? Unless your mods in your profile are wrong and you aren't running a t3 manifold and a 66mm BW turbo?
Not sure on the weight but it does still have full glass, owner says he could remove another 300lbs easy but that would be cheating, car has to go faster first.
He has been messing around with lower boost lately with good results.
As for power there is a dyno video somewhere on youtube, just look around for "mitsurage"
Just thinking and typing at the same time. Your right one has nothing to do with the other. The mirage makes 9s look so easy, and im curious about the setup and the potenial it has already shown. The bolt on housing has been 9.4s almost a decade ago. Others since, have proved 6xx awhp is about all one can make with the fp dsm bolt on equipment. What are the specs and weight of the mirage?
Thats insane. Any motor information or anything?
FFWD Connection 2.3L built 7 YEARS AGO.
