psychbiker1966
- 96
- 1
- Aug 14, 2007
Houston,
Texas
I am having a problem with coolant being pushed out into my overflow bottle and not returning when it cools. I have done the sniffer test and had it confirmed again by a shop no Hydro Carbons in the coolant. I have hooked up both my fans to come on together. The Temp gauge stays in the middle,No white smoke,car is running well. The rad cap is 3 months old as is the thermostat.I have good compression numbers. HG was done in February so I am tempted to retorque my ARPs if its leaking or something. I want to rule out my water pump or cooling system before I mess with the bolts. The car will push coolant into its overflow bottle and each day I have to transfer a full bottle back into the system myself. When I start it with the cap off I get frothy bubbling as if I'm getting air in the system. I have a video which won't load but I have a few pictures. The frothing gets worse so you don't see the green fluid if I run it longer. I can rev it up and it will spill over a little bit.. Can a water pump cause this or do I have a leaking headgasket (With no Hydrocarbons)??
