Bolt question?
markf671
71
Aug 4, 2004
Humble, Texas
I did a boost leak test on my car.... Found a big leak where j pipe meets turbo... It was my j pipe it was warped... So I bought a new one from ebay bolted it up... come to find out the holes on the turbo were stripped! So I tapped new holes with a 3/8 tap... I used 3/8 bolts from home depot & crushed washers... Will that be ok? I already bolted it up... Everything runs fine but in the long run....
Thank guys!
Mark
I use a nice thick homemade gasket for the jpipe. The flange is easy to warp so thicker gaskets can take up the irregularities of the surface, therefore no need to crank hard on those bolts to keep a good seal
Iugrad92turbo, I'll keep that in mind.... Thanks you for thIe info buddy! So cooper crush washer right?
NHerron, so what do you use to make the gasket?
One more thing guys, If I boost leak tested from the turbo will that be ok for the whole system? Or do I have to do the tb to check for leaks at the top....
Thanks again!
You can get them at the local auto store. They are a variety of thicknesses / material for different applications, usually about 5 sheets a pack for around $6.
A boost leak test starting at the compressor inlet tests the whole system. When doing the test, make sure to set the engine to 30* ATDC *so the valves aren't in overlap. Otherwise air might go out the exhaust
30* ATDC would be about 2 inches counterclockwise from the mark in the crank pulley, lined up to the 0* mark on the plastic cover.
Thanks! Herron,
Ok so that I under stand you... The compressor inlet is the turbo? And last question how do I get it to top dead center? Sorry for all the noob questions! I decided no more spending money on a shop, if I can do it myself! Lol!
Mark
Boom! Copy that! Thank you once again.... Real big help!
  • For sale 420A 420a heat shield
    $20 and free shipping. Need gone
    • Stizzydrew
  • For sale 420A 420a parts
    Stock Cam caps, lifters, rockers.
    • Stizzydrew
  • For sale 420A Stock 420a camshaft & cam gear
    Stock 420a camshaft and cam gears. $100 + shipping or best offer. I no longer will be using 420a...
    • Stizzydrew
  • For sale 420A 420a valve covers
    $40 + shipping / OEM Black 420a valve cover $100 + shipping / Powder coated candy red Valve...
    • Stizzydrew
  • Wanted 1g GSC S2 cams
    Looking for a set of good condition GSC S2’s.
    • I21chardh
