Correct Throttle Body Gaskets?
Thugmaster1220
74
Oct 26, 2011
Woodstock, Illinois
Hey just wondering if anyone can say withing a reasonable doubt that these are the correct gaskets....
Mitsubishi OEM Throttle Body Gaskets - 2G DSM 95-99 - OEM DSM Gaskets - Maintenance - DSM Performance Parts | DSMparts.com
Part# MD184046+MD302262
I took apart the throttle body and now its time to go back together but obviously I need to replace the odd worn gaskets. RockAuto sells the gasket between the throttle body and intake mani for $1.50 but I cant find the other one on their website, so before I pay way overprice of what it should cost, just wanted to make sure its the right stuff!
Shaft seals....?
Also Im working on getting everything going on my 2g, I replaced the whole ingition system, and now im gonna go at the fuel system.
So i found a guy on craigslist with an evo fuel pump and evo injectors. Whats a fair price to offer him for both injectors and pump?? Anything to watch for when purchasing used? He says 30k mi on both.
So then the question becomes, while replacing my fuel pump/injectors, I should probably replace the fuel filter as well, huh? There are 2? With these mods should i upgrade the filter or just OEM replacements?
Anything else I will need to complete this job... Fuel pump 0-ring? What else?
The shaft seals on the TB; they always leak! If you haven't done them recently I'm willing to bet a BLT will show decent leakage at the seals. If you do decide to change them watch out for the damn return spring, I sliced my hand up real good re-winding it LOL.
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2G DSM ECU
    $100 picked up 91605 CA $100 + Shipping Need gone don’t have the space for it.
    • Stizzydrew
  • For sale 1g Door cards
    Grey very good condition, pick up only
    • 93 talon tsi awd
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
