1g wireing
91 tsi turbo
Oct 5, 2011
tucson, Arizona
hello so i pulled the entire interior out of the car to fins i wasn't missing anything. although i found 2 plugs exactly alike and only 1 i see a spot for. from the harness under the dashboard there is a plug to the brake light switch. with that plug is a 2 prong plug shaped |-- im assuming that's the clutch sensor plug but then from the other half of the harness by the kick panel is another plug same one witch is for the sensor and where does the other go?
in another note i have the issue the rear half of my harness gets no power. i have looked over every bit of wiring and grounds.
my headlights also do not turn on but get voltage to the plug. they do turn on if i jump the relay tho.
the rear half of the harness does not however.
