2G Throttle Body Question
MistrMackey
98
Mar 31, 2012
olathe, Kansas
So my seals are bad in my throttle body , I ordered a new re manufactured part that has been bored out , I'm going to put this on the car while I fix my old one and then sell the old one. My question is do I need to have the the intake mani machined as well to match the bored out TB? I got it from steve at throttlebodys.com
If the bore is bigger then 52mm then yes you would have to hog out the intake manifold. The air would hit a wall if not properly port matched.
so what would my best option be to port the 2g intake manifold?
Its very easy to port the intake manifold with a dremmel, the aluminum is pretty soft. It took me like 10 min to port my 2g manifold for a 1g TB. I just put the 1g gasket on an traced the inside with a marker to see what needed to be removed.
+1.. thats the same thing I did. I did it when i had my motor ripped out getting rebuilt so it made things a little easier. Its a good time to get a new intake manifold gasket and thermo-spacer as well.
