For Sale 20G turbo, FP race mani, O2 dump
pneumo
3,763
61
Oct 19, 2002
Bay Area, California
For Sale
20G turbo, excellent condition. Downflow TD06 compressor cover, upgraded 34mm internal wastegate flapper with high pressure 21psi actuator, and larger TD06 turbine wheel. I did a few mods to get more power out of it, compressor inlet and outlet have been ported and smoothed, turbine housing has been ported and smoothed. Bearings are in excellent shape! Includes a special oil feed restrictor banjo for proper oil pressure. All bolt holes are clean with good threads. FYI it has one small crack in turbine housing, has no effect on performance. This turbo has made 458 AWHP on a Mustang dyno and ran 10.4 at 133 mph at just 27psi.---SOLD---
Forced Performance Race exhaust manifold. You've seen them, they're awesome! Low miles, only used on my weekend car for one year. Less than 5k miles on it. I did a little extra work to it and smoothed down the casting roughness to get a little more flow out of it. ---SOLD---
O2 housing with dump tube for internal wastegate. Flows great, full 2.5" all the way through. Looks a little rough but performs better than the cheap eBay copies. $ Make offer$
21psi wastegate actuator. Bolts onto any 14b, 16G, HTA 68, or any TD05 based compressor cover. Perfect for high boost setups. $50 OBO
Update,
FP mani sold,
20G sold,
O2 dump housing is still available.
Added a 21 psi wastegate actuator to the list. Perfect for high boost applications.
