coolant leak
samus21
150
Jan 27, 2012
York, Pennsylvania
I put a cold air intake on my car yesterday. I was driving around and when I got to a stop light I noticed my engine was smoking. I pulled over and found i had coolant alll over the left side of the engine bay. where would you look first for the leak? I dont see any visable leaks so it must be a coolant line tucked away or that I can't see without taking something apart.
If you can't find where the leak is, it could be the water pump. Check all the obvious things first, as the water pump is a pain in the butt to get to and replace.
You could add some highlighter fluid and check the car with a black light to find the leak if you are having a hard time.
