Bud92gsx
Welcome Wagon
- 23,183
- 428
- Jan 16, 2008
Wisconsin,
Wisconsin
Pulled the Vc and you will never guess what I found..STOCK EQUIPMENT..
I decided to fill a container with the thinner and water and scrub scrub dub. It work. Surprisingly. I've cleaned it off with simple green inside and out. I bought a dremel and some nice little things for it so I can to the fine touches of griding and polishing/cleaning and here's what I got so far guysYou must be logged in to view this image or video.You must be logged in to view this image or video.
Right now I'm sanding it with 800 then ill use 2000. Before I throw on a thing layer of primer.
My question is why use primer when I have high heat engine enamel?
Sent from my T-Mobile G2 using Tapatalk
but my hopes aren't up I'm just enjoying my first car show experiance and the valve cover really pulled everything together thanks you guys at dsmtunersPulled the Vc and you will never guess what I found..STOCK EQUIPMENT..
That looks super good man some nice black paint would really make that blue POP!
Its alright, Its normal for dsmtuners. Anyone have any ideas on something besides rubber gaskets that can be used for VCs I dont like the fact you can see the gasket if you look closely
Would you rather see oil when you look from far?
And...that is the saddest excuse for a Christmas tree I've ever seen. You should at least go grab some Micky D's happy meal toys to hang on it or something.
