1998 GSX Wont Turn over (click noise)
DSM Chase
778
51
Sep 19, 2011
Senoia, Georgia
Okay i drove my 98 gsx all day today fine, when i got home i shut her down and walked away for about 2 hours, came back to move her in the garage and it wont turn over. When i turn the ignition on all the lights on the dash come on and it just makes a click noise everytime i turn the key coming from right behind the radio.
New Starter
New starter relay
Brand new battery
Disabled the clutch push in safety start thing.
Still having the problem any ideas?
Sounds like connections to the battery are not tight. Pull them off, clean the connections on the harness itself (I usually use a flathead screw driver or knife so it's shiny), and re-install them. Make sure they are tight. Then try it.
I had a problem like 4hrs ago similar to this...I took out the clutch safety thing aswell BTW...... But my problem was the thick positive cable that runs to the starter was bad and it broke off ....all it did was click one and after a while trying it the starter got really hot.....but go check that cable it might help
.....I think it connects to the solenoid or however you spell it
I had a similar situation about a month ago. Ran fine all day. Came back later to start her up and only clicks. I will say that I had it clicking repeatedly while trying to start. It was a fried starter. If you are only hearing one click and nothing I would say it is a bad ground in the circuit to the starter.
Try opening the car manually with your key in the door lock. Sounds to me like you anti-theft system is acting up. Or your starter committed suicide
only 1 click not multiple clicks, The battery is fine trust me the lights and everything, radio work fine. positive its not the starter or the battery connectors. Everything is tight and secured.
That was the first thing i did, no joy
Inspect battery cable and starter cables. there have lots of post on this subject. search the threads.
everything can be tight and secured but doesn't mean it's working. i'd take a look at it if i were you and not assume.
Have you inspected all of your cables going to the B S and M terminals on the starter? It only clicks once? that tells me that the solenoid is receiving sufficient current to engage the pull in winding. Does the starter or any starter circuit wires feel hot after a few attempts to start?
I'll attach a wiring diagram courtesy of alldata :thumb:
had same problem in my 95 GST ended up being loose wires under the dash check EVERYTHING!! It will be the cheapest most little thing you will expect 9/10 in a dsm.
