PL69
- Apr 11, 2008
Sherbrooke,
1999 Eclipse GS-T Spyder
Noir/Tan
Manual 5 vitesses
43 000 miles (69 000 km)
I am the second Owner I baught the car at 32 000miles, it came from Florida and as never been involved in any accident.
Engine/Performance
- Brian Crower 272 Camshafts
- Phenolic Intake Spacer
- 1G ThrottleBody
- Punishment Racing 2G Intercooler Aluminum Piping (Keep Fog OEM)
- Forced Performance Intake Pipe
- K&N Air Filter
- Evap/Canister Delete
- 1G BOV/Bitbitte a BOV
- Accel 8mm Wires
- EVO 8 Fuel Pump
- Injecteurs PTE 780cc
- Forced Performance HTA68
- Evo III Exhaust Manifold
- SS O2 Housing
- SS 3'' Downpipe
- 3'' Exhaust Cut-Out
Drivetrain
- Fidenza Flywheel
- ACT 2100 Clutch
- Accumulator Delete
- SS Clutch Line
- Solid Shifter Cable Bushings
- ES Shifter Base Bushings
- Pinne du Diff Souder
- Insert de Support a Moteur Avant et Arriere ES
Note: The transmission has been welded inside the bellhouding due to a diff failure and is slowly leaking, its such a slow leak that you only have to check the level at every 4-5k oil change. This could be easily welded back by onle removing the transmission.
Suspension
- 2G Big Brakes
- EBC Green Pads
- SS Brake Lines
- RM Rear Swar-Bar
- Tokico Illumina (non-installed)
- Wheels OEM Chrome 16inch Almost New Goodyear RS-A
- 4x 17'' Rota Attack (Must be painted no tires Xtra 200$) 1 wheel is a bit warped but balances no problem and does not vibrate at 200km et +
- 4x Toyo Proxes 4 about 10/32eme (Xtra 400 $)
Électronique/Inside
- DSMLink V3 Lite
- HKS EVC 4
- Innovate LM Wideband (sensor not installed)
- Prosports Boost Gauge
- Prosports Fuel Pressure Gauge
- HKS Turbo-Timer (not installed)
Many parts to do AWD swap are available
- Crossmember rear AWD
- Tank a gaz AWD
- Shafts rear
- Diff rear
- Driveshaft
- Spindles right and left Complet
Prix: 14 500 $ negociable
I am located in Sherbrooke, Quebec, Canada
[email protected]
819-993-9003
Noir/Tan
Manual 5 vitesses
Engine/Performance
- 1G ThrottleBody
- K&N Air Filter
- Accel 8mm Wires
- EVO 8 Fuel Pump
- SS O2 Housing
- SS 3'' Downpipe
Drivetrain
- Fidenza Flywheel
- ACT 2100 Clutch
- SS Clutch Line
Suspension
- 2G Big Brakes
- EBC Green Pads
- SS Brake Lines
- RM Rear Swar-Bar
Électronique/Inside
- DSMLink V3 Lite
- HKS EVC 4
- Tank a gaz AWD
- Shafts rear
- Diff rear
- Driveshaft
[email protected]
819-993-9003
