lightworkerDSM
- 32
- Sep 15, 2009
San Jacinto,
California
My car is misfiring like it has cams it idles like it wants to die, my car is stock, the check engine light is NOT on what can it be please help.
Wow, good catch.your not venting your bov are you?
i have never seen stock fpr go bad on a 2g. sometimes when venting it throws out these weird fuel related codes depending on the car, as venting is BAD on our cars without running proper blowthru setup.
You need to recirculate your bov back into the intake before you spend money replacing your fpr, typically the only time a OEM fpr would fail is after you upgrade to a higer flowing fuel pump.It is vented and the code said malfunction on fpr.
I put a 1g fuel rail with the fpr attached to it and still doing the same thing.
Do this still ^^^....if it feels like its not getting enough fuel change the fuel filter or at the least check your fuel pressure at idle using the owners manual (43.5psi is where it should be).
