gofer
Moderator
- 8,165
- 1,556
- Feb 18, 2006
South Gilbert,
Arizona
Everything looks like its doing what its supposed to which is always a good feeling. I see your still throwing the alternator CEL, still running your stock 450cc injectors, and haven't installed that WB but one thing at a time Brian, I know your busy doing the family thing.Ok, so here are 2 logs with what gofer told me to add. any input on them would be great. hopefully i did them correct. Gofer i have a new throttle body coming with the TPS and IAC. so my idle problem should go away.
Add one more thing to your captured/displayed values... ClosedLoop and start your log while its idling and let it warm up (coolant temp 180* +) then go for a drive, keeping the same log going. While your driving you'll want to try to keep the car in ClosedLoop operation as much as possible for a good MAFComp log. To keep it in ClosedLoop I like to drive in hilly areas or going more than 50% throttle onto interstate on ramps. We're not trying to do WOT tuning so don't go mashing the gas pedal, just let the engine see some boost.
The good news is I KNOW that your ISC is bad just but looking at the logged ISCPosition value you have logged in link. Next on your plate is the Evo injector install, WB o2 install, & new alternator?
(and take care of the kids)
, i'm tryn bro. Taking the kids to see alice in wonderland tonight. So after that im heading to the garage to install the WB, and the 510's. I will be able to uy a new alternator next week if funds allow it. And fix my pesky coolant leak.
