AFPR question
starfish
450
2
Feb 20, 2010
Hamilton, New Jersey
I need to know if this is FMU or AFPR.will this work on my turbo kit without using a S-AFC. It has a gauge,ajustment screw on top and vacume fitting.and the two fittings that go between the return.please help ,I need to drive the car to work monday.
Sorry about the anger.Lot of pressure right now.not very good with a computer,not like you youngins!Thanx for fixin me up
I read somewhere that you should allways prime a new turbo.Is this true? How exactly is this done?What kind of oil?
That is an AFPR, and is not suited to boosting a 420a unless you're using a PortFueler or MegaSquirt for engine management.
SAFC's are not very useful on turbocharged 420a motors, due to the need to hide boost from the ECU.
You can prime a turbo by running the oil pump. (cranking the motor without starting)
every body says a S-afc is what you need to tune your turbo 420A,is this true?this afpr is the one that came with the 420A turbo kit.
Hell no.. I had an afc in my 2gnt w/ T and it was nothing but a headache.. I would do 2nd gear pulls and everytime the wideband would read way off without even adjusting afc.. That thing will help you idle with big injectors . thats it
You need an FMU to run boost, preferably a 12:1 FMU. An afpr is basically a 1:1 rising rate unit, with the ability to adjust idle fuel pressure.
As for using the safc... don't. There's a sticky that Paul made somewhere in the 420a section, if you want more detail.
