cardot33
- 182
- Apr 2, 2009
Amboy,
Illinois
how does the slave cylinder operate when being bled? when the pedal is to the floor and the bleeder valve is opened should it retract back toward the cylinder (drivers/engine side) or should it just pour fluid out of the bleeder valve while the piston remains stationary? the reason being is because I'm having shift problems despite replacing MANY transmission related parts including the clutch and adjusting the clutch and shift cables. The car will start in gear and take off fine, but while running, this thing refuses to go in 1st and 2nd. The slave cylinder is one of the few parts I haven't replaced yet so I'm wondering if it's bad too.
this sucks. should go a lot faster this time at least.
