MAS connector wiring
regulator213
109
2
Jul 10, 2009
McGuire AFB, New Jersey
I have bought two connectors for my MAS as the car i purchased came with the connector cut off. The car side of the harness matches up with the schematics Snowboarder714 posted here http://www.dsmtuners.com/forums/151528378-post13.html However both connectors have a different wire color setup than my car harness. Both of them match each other yet both of them supposedly came from a 2g. In fact one of them was said to come from a 98 GST which is the same year and model car that i have and still the colors do not match up. The colors on the connectors that i have look like this...
from passenger to driver side: GW RL B BR WB P GY
G = Green
W = White
R = Red
L = Blue
B = Black
P = Pink
Y = Yellow
If i just use the schematic from Snowboarder to match up the pin locations on the connector instead of using the wire colors will that still work?
Also has anybody seen a connector with those colors? if so where did it come from?
The link that Snowboarder714 posted is the correct 2g wiring. I checked it through Mitchell and it matches up. What I would do is match up the wires on your car to the corresponding colors so;
Connector=Harness
GW=RW
RL=RL
B=B
BR=R
WB=SBY
P=O
GY=GY
