talondsm24
- 102
- Aug 28, 2009
Arvada,
Colorado
ok so ive only got 10 days and i really need to get my car to pass. here are the numbers
reading limit
HC 4.9903 2.0
CO 21.1271 20.0
CO2 418.9672
NOx 7.4658 3.5
i put in a few thing before the test like put some lucas oil, fuel injector cleaner, and a seal up additive in the oil as well as drove on the highway to get everything really hot.
What should i do?!!!
reading limit
HC 4.9903 2.0
CO 21.1271 20.0
CO2 418.9672
NOx 7.4658 3.5
so what i did was turned my biss screw all the way in and my car passed. i would count how many turns it takes that way after emissions you can set it back to the way it was. my cars idle dropped really low when you would let off the gas but it stayed runnin and the turbo wouldnt boost past 7psi (normally 10psi) and passed no problem! if it wants to die on you, you can always open the throttle up just a little bit by adjusting the cable. if all fail register it in one of our mountain towns with no emissions
but shhhh dont tell no1
