TSIMonsteR
- 1,872
- 24
- Nov 23, 2003
HP,
North Carolina
I searched, and found many threads and tried many things from those threads, but no luck.
Car won't turn over suddenly. Its been fine. I came home for lunch day, went in for like 15 minutes or so, came back out and the car won't start/turnover at all.
I checked and re-tightened the battery terminals. No luck.
DSMLink reports 12v coming from the battery and everything seems to work fine electronic wise, but I tried to jump it off anyway, but it won't turn over at all.
I tested all the fuses, none were blown, and I went ahead and replaced any fuses that I though could be hindering the problem. (even though the tested good via the Multi-Meter)
I assume it has something to do with the starter relays. I figure, if it was the starter, it wouldn't be such a sudden change. I would have had symptoms leading up to a starter failure.
As far as I know there are really only 2 relays that could be the culprits. The starter relay behind the radio, or the one above the driver side fuse box.
When I turn the key, the one behind the radio clicks, should it? I tried removing the theft/starter relay (the one above the interior fuse box) but it didn't change anything.
What should I look for/try next?
