turboglenn
- 6,375
- 123
- Nov 5, 2007
RIpley,
West Virginia
This weekend i picked up a sine vise for my mill and decided to try back-cutting a set of gears for a drag bike i'm working on currenly ( i usually friction grind this process by hand) but anyway.. My first mill i tried (TiN Rouching mill 1/4'' diameter with 1/2 inch shank) wouldn't do anything worth mentioning.
Then i tried the good ol' HSS 3/8 sank and diameter and again made about .010 prgress at .003 depth and that was the end of that end mill.
I've always just done this by hand but would like o throw the mill in the mix for a more precise and better looking final project (not that the looks matter or that the customers ever even see the parts, but i's mor my personal satisfction)
what do you guys use to cut tranny gears? I have turned them on the lathe using carbde inserts so i know they can be cut, but with what i don't know.. I figured there were others milling gears instead of hand grinding still so hopefully some read this and can help
